Re a `93 with 35,000 miles. 40th Anniversary.
A friend called and asked if I had heard of a problem with moisture getting into the Distributor and rust causing a misfire.
The garage wants to change the distributor cap and internals and the water pump at the same time. Apparently the water pump has to come off to get to the distributor.
Any feed back on this problem?
